DNSWindows .bat File
Discussion in '3CX Phone System - General' started by HowardMaxfield241, Nov 30, 2017.
  1. HowardMaxfield241
    Nov 24, 2017
    10
    So I installed my failover server but am having issues with the DNS not switching over to the failover server once its initiated. I downloaded the scripts to do so however Im at a lose how to configure them. Has anyone configured them before?
  2. StefanW
    Jun 2, 2009
    1,218
    90
    it depends on your environment, if you use a public 3CX FQDN, then we will deal with the change for you (but it will take time until the TTL expires unless you use en ENT license). If you need to alter internal DNS infos, then refere to the admin guide of your DNS service and if it is a Windows DNS server, alter as per document also the Service Running User. Note on Linux based PBXes you can not alter so easy a windows dns entrie...
  3. HowardMaxfield241
    Nov 24, 2017
    10
    Well the issue im having is that when the failover is initiated phones wont provision to the FQDN. Nor can I access the web management console from the FQDN.
  4. StefanW
    Jun 2, 2009
    1,218
    90
    and where are the phones located, in your network or remote?
  5. HowardMaxfield241
    Nov 24, 2017
    10
    All in the same network.
