Do I have to license VAD even for the free components?
Discussion in 'CRM / Helpdesk / App Integration' started by AdemMeral, Jul 22, 2010.
  1. AdemMeral
    Jul 22, 2010
    I am not able to run even a simple playback with VAD.
    I have Installed version 9 of 3cx and Version 2 of VAD . I deploy the app without error but when I call 851 with 3cx Phone 4 it hangs up after 3 seconds.
    Do I Have to install the server components mentioned on some posts ? How can I get them?
    Adem
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    HI,
    Server components are pre-installed since 3CX version 8, so you don't need to install them. And you should be able to use the free components without a license.
    Are you using IIS or Abyss web server in 3CX? Maybe you need to make some adjustments to the deployment options of the project. Take a look at this post, and verify if those options are correclty configured:
    http://www.3cx.com/forums/an-error-occured-in-ivr-session-v9-vad-v2-15983.html
  3. AdemMeral
    Jul 22, 2010
    Hi, no that post didnt help as I had already read and tried it. It doesnt even deploy if I change the port.
    Uninstalling and Installing with IIS instead of Abyss solved the problem. It seems Abyss has some problems , and it may be due to Turkish locales (My Guess).
    Thanks for your time.
    Adem
  4. VAD_Support
    Aug 6, 2009
    690
    Maybe Turkish locales have problems with Abyss, I never tried.
    To get detailed information about IVR errors, you can always check out the log file %ProgramData%\3CX\Data\Logs\3CXIvrServer.log
  5. gymbo86
    Jul 15, 2009
    Checked and double checked... 3XC Voice Application Designer Server Component is definitely not installed... This is a clean install of V9.
    When I try to deploy a work flow to the server (remotely) I get the following error;
    An error occurred while deploying the project:
    Could not connect to the deployment URI. Verify that 3CX Phone System has the 3CX Voice Application Designer Server Components installed. Also verify the PbxDeploymentUri property for the project.
    The remote server returned an error: (404) Not Found.
    As per the link you posted I have adjusted the port setting for Abyss web server and this is the result.
    Any help appreciated.
  6. VAD_Support
    Aug 6, 2009
    690
    Server side components are only 3 files in 3CX server located at %ProgramData%\3CX\Data\Http\Interface\ivr:
    VAD_Deploy.aspx
    VAD_DownloadDebugInfoFile.aspx
    VAD_GetDebugInfoFileNames.aspx
    If you have those files, then server side components are installed.
    When you deploy a project remotely, you need to allow remote access to the configuration, as described in the user's manual. To do that you need to change the 3CX Phone System.ini file and restart the services. Have you done that?
  7. gymbo86
    Jul 15, 2009
    Checked for files... all good..
    Definitely allowed remote access as per manual. Also have tried installing VAD builder on server machine.. Still getting the same error.
  8. VAD_Support
    Aug 6, 2009
    690
    Have you checked the firewall settings? When using Abyss in 3CX you need to open port 5481. When using IIS you need to open port 80. Are you using Abyss or IIS?
  9. gymbo86
    Jul 15, 2009
    Abyss .. and no firewall active at present.
  10. VAD_Support
    Aug 6, 2009
    690
    What value has the property PbxDeploymentUri for the project? You can check it in the Properties Window after selecting the project in the Project Explorer Window.
  11. gymbo86
    Jul 15, 2009
    I've attached a screen grab.
  12. VAD_Support
    Aug 6, 2009
    690
    The PbxConfigurationPort should be 5485. The port number 5481 is for the URIs, because that's where the web server is listening for requests. But the configuration server listens in 5485.
    Try changing that and let me know.
