Do I need a PBX software?
Discussion in '3CX Phone System - General' started by networkers, Jan 10, 2012.
  1. networkers
    Jul 1, 2010
    9
    3CX can certainly do all of the above.
    3CX "takes over" the SIP accounts, so your phone registers with the 3CX server, and the 3CX server registers with your SIP accounts. In 3CX you can forward calls based on a number of parameters, time, callerID, SIP account and so on.
    You will be able to route calls to either your phone, your wifes phone, ýour mobile phone, voice-mail... there's almost no limits.
    You should try 3CX out, remember that there is a free version avaliable for you to try. (And keep :) )
    10,758
    286
    With only a couple of users (extensions) and 7 trunks (providers). You would probably want to create a ring group with both extensions (or even more). This way all the phones would ring during an incoming call. If you had two appearances of the same extension number on each set, then you could use the hold feature on the set to take a second call.
    You only register 3CX to your providers, the sets then register to 3CX.
    Many users do just this for travel (I do), or have extensions permanently, elsewhere in the world.
    You will still need a Windows based PC running 24/7
