Do I Need active maintenance to upgrade?
Discussion in '3CX Phone System - General' started by Haeyl, Dec 12, 2016.
  1. Haeyl
    Dec 11, 2016
    6
    Question in the title, the maintenance license on my company's 3CX v14 has run out. Now my director is wanting to upgrade to v15 but I've just heard that waithout a license you cannot upgrade. Can't we just buy the upgrade?
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    To upgrade you need your maintenance to be current. If you are more than two months past the maintenance period of your license you can purchase a "version upgrade" which will bring you back to the latest version with 1 year of active maintenance. Going forward you should always purchase the annual maintenance. Maintenance is approx 25% of base license cost and Version Upgrade is about 80% of base license cost.
    http://www.3cx.com/ordering/pricing/upgrades/ look for "Version Upgrades".
  3. Haeyl
    Dec 11, 2016
    6
    thanks for the link, I've looked at that before. Our maintenance license is most certainly out of date (before my time or I would have made sure they kept it active). Our system is version 14 with 4 sim calls, am I right in assuming that upgrading to 15 would cost 179 Euro?
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,422
    538
    I think that asking for prices in the forum will not serve you well as you could get wrong information. Make a call to our sales department in the number found in the link. They will be able to offer you far more details http://www.3cx.com/company/contact/
  5. Haeyl
    Dec 11, 2016
    6
    cheers, will do
