Do I need VPN
Discussion in '3CX Phone System - General' started by brentkhack, Apr 22, 2015.
  1. brentkhack
    Apr 17, 2015
    24
    New user that is still trying to get system up and running. I was told I needed a VPN router to make the 3CX to work. I am using nexVortex as VOIP. I want to make sure I will not be loosing features or security by not having a VPN router so I can return the Cisco RV042G.
    10,868
    304
    You would use VPN if...
    Any device/router/site was making use of VPN, for a secure connection to the server.
    You wanted to be able to access 3CX remotely/securely, to make changes.
    You required access to other devices, server, etc., on your network
  3. brentkhack
    Apr 17, 2015
    24
    Would you do VPN or logmein.com if you had to remote access the computer?
  4. leejor
    10,868
    304
    I have not used logmein, so i can't comment. I do use VPN through a router running DD-WRT firmware, which allows me, remote access and occasionally a SIP connection (when all else fails) with my Android 3CX Phone. It is only PPTP, which is not the most secure version of VPN, but it's better than nothing.
  5. brentkhack
    Apr 17, 2015
    24
    Thank you for the info. I am not sure I can even take back the router since I threw away the box. I only understood half of what you said :D
  6. brentkhack
    Apr 17, 2015
    24
    The company I bought the 3CX from said I do need a VPN to route VoIP traffic.
  7. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,155
    176
    For one office, no you do not need a VPN - just configure the firewall with the correct ports open - http://www.3cx.com/docs/firewall-router-configuration-voip/
    Only really need vpn, when connecting to two sites together
  8. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,416
    277
    ...and even then it is not a requirement.
    I had 3 offices on 3cx all talking to each other via the Bridge as well as 7 external users connecting to the main site from home... no VPN in use.
