Do internal Calls count against licenced number Simul calls?
Discussion in '3CX Phone System - General' started by marcusjclifford, Apr 25, 2012.
  1. marcusjclifford
    Apr 17, 2012
    25
    I was reading the 3CX book "The 3CX IP PBX Tutorial" last night and came across this:
    Unfortunately that link no longer works, but is what has been said still true - the licences required are based on external only calls, so for example with 4 licences there could be say 7 internal calls going on between extensions without violating licence?
    Thanks in advance,
    Marcus
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,591
    309
    Re: Do internal Calls count against licenced number Simul ca
    No - internal calls DO COUNT against the license.
    I currently have a 4 license demo unit in place during setup and can easily max out...
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Licenses are needed for the following:
    External to internal - 1 license
    Internal to external - 1 license
    Internal to internal - 1 license
    External to voicemail - 1 license
    Internal to voicemail - 1 license
    Conference calls - 1 license per person in call
  4. marcusjclifford
    Apr 17, 2012
    25
    Thanks, I thought the same as both of you have posted.
    It's a shame when a book supposedly about the product makes such incorrect statements :(
  5. craigreilly
    Feb 1, 2012
    3,591
    309
    The statement you posted comes from the book?
    It says they DO count...
  6. KerryG
    Jun 19, 2009
    960
    If there is an error in my book, please let me know.
