Do Not reference "in office" anywhere when 3CX is hosted
Discussion in 'Ideas' started by the60, Nov 29, 2017.
Do Not reference "in office" anywhere when 3CX is hosted 5 5 9votes
5/5, 9 votes
  1. the60
    the60 New Member
    Oct 21, 2011
    117
    63
    3CX references "in office" for links to reports, webclient, etc.
    when a 3CX is hosted, there should never be any reference to "in office" Vs. "out of office" for links, downloads, webclient, even 3CX client.
    Hosted systems are never on the LAN.
    Users don't understand this differentiation and it's confusing.
    Lastly, tweaking email templates repeatedly is not practical.
  2. Nathan Boyd
    Feb 2, 2017
    47
    11
    This is a good point, a simple "Is this system hosted" and/or a check for the common hosting platforms (OVH, AWS, GCP, etc) during the initial Text/Web setup could easily take care of this. A separate set of templates that don't reference "in office" at all could be utilized instead.
    the60 likes this.
  3. Silly English Kniggit
    Sep 13, 2017
    220
    90
    That's quite a good idea!
    the60 likes this.
  4. accentlogic
    accentlogic New Member
    Nov 14, 2013
    190
    79
    +1.
    A simple checkbox in Settings, PBX or Network would be sufficient - and then add an IF to the email templates.
