Do not regist only a specific extension
Discussion in 'Android' started by chikara sugiyama, Aug 24, 2014.
  1. chikara sugiyama
    Jun 15, 2014
    22
    Hi there
    Suddenly, a specific extension is no longer regist.
    There is no problem in another extension.
    There is no problem in the fixed telephone Windows or extension in question.
    IP is not blocked.
    Both LTE and Wi-Fi is also the same.
    Service in the server is all normal.
    It does not have NAT or FW.
    only once before it will not regist, I just made ​​a Re-Provision.
    Contents corresponding are as follows.
    1. Restart Windows
    2. Reconfiguration and deletion of extension
    3. Uninstall and reinstall the Android 3CX
    4. Change of network connection
    In addition, the following contents are followed by log
    Code:
    24-8-2014 10:15:47.960	[CM504002]: Endpoint Extn:201: a contact is unregistered. Contact(s): [sip:201@111.111.111.111:56670 / 201,sip:201@127.0.0.1:5488 / 201,sip:201@111.111.111.111:5060 / 201]
    24-8-2014 10:15:47.959	[CM504002]: Endpoint Extn:201: a contact is unregistered. Contact(s): [sip:201@111.111.111.111:56670 / 201,sip:201@127.0.0.1:5488 / 201,sip:201@111.111.111.111:5060 / 201]
    24-8-2014 10:15:47.886	[CM504002]: Endpoint Extn:201: a contact is unregistered. Contact(s): [sip:201@111.111.111.111:56670 / 201,sip:201@127.0.0.1:5488 / 201,sip:201@222.222.222.222:39440 / 201,sip:201@111.111.111.111:5060 / 201]
    24-8-2014 10:15:47.840	[CM504002]: Endpoint Extn:201: a contact is unregistered. Contact(s): [sip:201@111.111.111.111:56670 / 201,sip:201@127.0.0.1:5488 / 201,sip:201@222.222.222.222:39440 / 201,sip:201@111.111.111.111:5060 / 201]
    24-8-2014 10:15:47.831	[CM504001]: Endpoint Extn:201: new contact is registered. Contact(s): [sip:201@111.111.111.111:56670 / 201,sip:201@127.0.0.1:5488 / 201,sip:201@222.222.222.222:39440 / 201,sip:201@111.111.111.111:5060 / 201]
    Thank you for your attention.
  2. chikara sugiyama
    Jun 15, 2014
    22
    It was self-resolving, but ...
    We were able to connect if you turn ON the tunnel, but the tunnel is needed? In an environment in which there is no NAT or FW on the server side?
    Server has been set directly globalIp address, there is no NAT or FW.
    It was a tendency that regist may become unstable if you turn ON the tunnel, where he was to OFF about a week.
    There is no problem even now OFF
