Do not save voicemails that are less than 2000 seconds ** [BUG CONFIRMED]
Discussion in '3CX Phone System - General' started by cobaltit, Jun 25, 2016.
  1. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,610
    243
    In v14 the setting is in milliseconds. In v15 it is in seconds. So when I restored my v14 config to v15 beta, the min length went from 2 seconds to 2000 seconds. Took me a sec to figure out why I wasn't getting voicemails.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    Re: Do not save voicemails that are less than bug
    yes we did this value in seconds.. - So in new installs this should be "2".
    But when you restore a backup we made a check not to restore this value and reset it for everyone to "2" as a new default. We will check why this conversion did not occur.
    We will check ASAP - thanks for reporting..
