Do SPA50x have a log?
Discussion in '3CX Phone System - General' started by ZenMasta, May 15, 2012.
  1. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    One of my phones seems to keep resetting and I would like to figure out if its badhardware or some strange config issue.
    Do these phones have an internal log that's available? I can't notice it off hand on the phones web ui.
    3cx doesn't show anything unusual, just that it un/registered.
    11,084
    325
    The only thing it might have (their ATA's do), is a setting (IP destination) for use with a Syslog server. If it does, you'd have to install the server ( these guys have a free trial, but there should be others, if you do a search.. http://www.solarwinds.com/register/kiwi_registration.aspx?Program=876&c=70150000000Es8J ) on another PC, then point the sets logs to that IP.
  3. active5
    Jun 28, 2011
    72
    Sounds like it could be a resync issue under provisioning.
    Check for "Resync Periodic:", under "Provisioning" tab, I set all my SPA50x's to 0 (numeric zero), also check your provisioning template, when the phone is reprovisioned it will revert back the default setting and resync every number of seconds in the field.
  4. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    I found the syslog field I'll see if that works out for me.
