DOD - Number
Discussion in '3CX Phone System - General' started by Andrew Aguilar, Nov 21, 2017.
  1. Andrew Aguilar
    Oct 11, 2017
    15
    Hi Guys,
    I just wanted to know, where to set DOD in 3cx?
    I'm going to integrate my 3cx to SIP Trunk, sip trunk need to know what telephone number use when dialing out. To make the outbound call be successful.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,473
    284
  3. Andrew Aguilar
    Oct 11, 2017
    15
    Hi Support,
    We install 3cx professional 15.5 and we used SIP Trunk for the trunklines.
    The inbound is ok, but the outbound isn't ok.
    What the SIP Trunk provider need to know is what number that 3cx use when dialing out.
    Where can we set the pilot number? For the SIP Trunk knows what number that 3cx use when dialing out.
  4. 12494
    12494 Member
    Apr 16, 2010
    281
    22
    You set the Caller ID in the SIP Trunk on the Caller ID tab.
    You can also set it in each extension's configuration if you want to override the CID setting for the trunk.
