Does 3CX client supports for mobile phone vendor push service?
Discussion in 'Android' started by OscarBalaBala, Jul 18, 2017.
Tags:
  1. OscarBalaBala
    Jul 18, 2017
    Does 3CX client supports for mobile phone vendor push service? Such as samsung push service, Huawei push service and so on.
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    3CX Client for Android based on the new Google Firebase. No other vendor is supported.
    Thank You
