Does 3CX client works well with Iphone 6 ?
Discussion in 'iOS' started by cyclone76, Apr 12, 2017.
  1. cyclone76
    Mar 3, 2017
    44
    Does 3CX client found on Apple store work well with Iphone 6 ?
    Is the configuration as easy as on Android with the reception of a mail ?
    Does push work well ?
    Regards
  2. cyclone76
    Mar 3, 2017
    44
    No answer ?
  3. paurus
    Jan 20, 2017
    91
    14
    I have a Iphone 6 works without problems
  4. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Hi @cyclone76 ,
    Yes it works fine on iPhones, as long as you have iOS > 10.0.
    Yes the provisioning is done via an email. You open the attachment, select 3CX and you are pretty much done.
    You can always download and test it :)
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    I am using with a 6+ - did have to re-provision recently due to no PUSH.
    Working fine now.
    I use Outlook on my iOS and it took just a couple steps to provision client.
    Tap attachment, click send to arrow, then "copy to 3cx".
