Does 3CX have an internal buffer for CDR records?
Discussion in '3CX Phone System - General' started by ct2ksupport, Apr 20, 2016.
  1. ct2ksupport
    Apr 19, 2016
    For the purpose of call billing and call reports does the 3CX system have an internal buffer so if connection is lost to the client call records will be kept locally until connectivity is resumed?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    If using any one of the socket options buffering is not available. What you could do though is generate the CDR to a file on the 3CX Server and then just have the client that parses the data connect and retrieve the information from the file.
