does 3CX run on Windows Server 2008 R2?
Discussion in '3CX Phone System - General' started by rodster, Jan 20, 2010.
  1. rodster
    Aug 19, 2009
    13
    The docs says 3CX support Windows Server 2008. Does anyone have any experience running 3CX on Windows Server 2008 R2 (64bit)? are there any potential problems? Thanks.
    Rodney
  2. carltoncl
    Dec 13, 2007
    25
    We have been running 3CX on Windows Server 2008 32-bit for 8 months now, no problems at all. We are using a Dell R300 server with 2Gb of RAM and a RAID 1 setup, absolutely no problems coping with 7 - 10 simultaneous calls with recording.
    However the company that built out our 3CX platform strongly recommended against using the 64-bit version of Windows Server 2008.
  3. comresource
    comresource Member
    May 22, 2009
    303
    We have a client running on Windows Foundation 2008 R2 for the last couple weeks. No 'major' issues.
  4. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    WITH 64 BIT HERE, RUNNING PERFECT... why did they not recommend it?
  5. swim
    Sep 23, 2008
    26
    We have been running server 2008 R2 64bit for last 4 months .... no issues
  6. rodster
    Aug 19, 2009
    13
    Thank you everyone for sharing your experience. I just need to assure the customer that Server 2008 R2 (which is available only on 64bit) won't have any problem with 3CX. Highly appreciate all the responses.
  7. mbulles
    Jan 18, 2010
    15
    I'm Running it on a Atom 330 works very wel with 2008R2l!
