Does 3CX support the Fanvil C600
Discussion in '3CX Phone System - General' started by pc62, Jan 31, 2016.
  1. pc62
    Apr 23, 2015
    Does 3CX support the Fanvil C600 ? The 3cx management console does not seem to detect it and when I try to manually add it I do not see it in the drop down list with all the different phone models ? :|
    10,747
    284
    Fanvils site mentions a few models that are compatible with 3CX, but that model doesn't seem to be on the list, not that it won't work, but might require some effort.
    http://www.fanvil.hk/index.php/auto-provisioning-fanvil-c58p-c62p-ip-phones-for-3cx/
    http://www.fanvil.com/List.asp?C-1-191.html
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    No, this model does not yet have a provisioning template. I have a C400 that I have been playing around with a bit, and you can easily (manually) provision it to work with 3CX. It seems to be a good phone, but my one regret about it is that unlike some other Android based phones, the Android Store is not available.
    I assume the C600 can also be as easily provisioned as I did see one being demonstrated at a 3CX class in Dallas earlier last year by the hosting distributor.
