Does it work with background ? (solved)
Discussion in 'iOS' started by deer307, Feb 25, 2013.
  1. deer307
    Nov 11, 2008
    Hi-
    I'm using 3CXPhone on iPhone 4s with iOS 6 , but Phone will not ring if it is in sleep mode.
    By the way , the skype and msn is working fine with sleep mode.
    How can fit it.
    Best Regards,
  2. StefanW
    Jun 2, 2009
    1,236
    96
    Re: Does it work with background ?
    this will be defenetly solved for you in Version 3.1 and PBX V12, stay tuned what we will have for you...
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    Looking forward to all the goodies in v12.
  4. secnet
    Sep 17, 2010
    8
    I've got the same problem, but with PBX v12 beta 2 and 3CX Phone v12.0.4 for iOS (ver6).
    Extension is unregistered (both in 3G mode and WiFi mode) when phone gets turned off.
    Any ideas?
  5. StefanW
    Jun 2, 2009
    1,236
    96
    it is to expect once hitting the home button that we as application unregister from the pbx but u should see directly a 3CXPush Service register on ur REG. But you need to enabled this.
    May use google translate to check it out my german how to about v12 and push...
    http://translate.google.de/translate?sl=de&tl=en&js=n&prev=_t&hl=de&ie=UTF-8&u=http%3A%2F%2Fwww.3cx.de%2Fblog%2F3cxphone-push%2F&act=url
  6. fhiadmin
    Jun 19, 2013
    10
    Is this fixed only through v12 which uses the 3CX pbx? I seem to have the same issue with 3CX V3. I'm not sure if the keep alive and registration settings would affect that. Also are those settings in minutes or seconds?
  7. fhiadmin
    Jun 19, 2013
    10
    When is v3.1 scheduled to be released?
  8. kevin
    kevin Member
    Nov 23, 2006
    316
    No schedule, except "when it's ready" ;)
  9. StefanW
    Jun 2, 2009
    1,236
    96
    hello 3.1 is called now 12. so get the new client from the app store to have push services from the pbx to the phone
