- Joined
- Feb 2, 2012
- Messages
- 2
- Reaction score
- 0
Good afternoon. Tell me. 3cx v.11 does not accept incoming faxes. all set, but as soon as the signal gets to the number of virtual Fax it resets. In what may be the case.
log:
16-дек-2013 11:44:22.421 [MS105000] C:3.3: No RTP packets were received:remoteAddr=127.0.0.1:10002,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7012
16-дек-2013 11:44:21.031 Leg L:3.3[Fax] is terminated: Cause: BYE from PBX
16-дек-2013 11:44:21.031 [CM503008]: Call(C:3): Call is terminated
16-дек-2013 11:44:20.953 Leg L:3.1[Line:10000<<+79263842897] is terminated: Cause: BYE from PBX
16-дек-2013 11:44:19.406 Leg L:3.2[Ivr] is terminated: Cause: BYE from 127.0.0.1:40600
16-дек-2013 11:44:19.203 [CM503007]: Call(C:3): Fax:888 has joined, contact <sip:[email protected]:5100>
16-дек-2013 11:44:19.203 L:3.3[Fax] has joined to L:3.1[Line:10000<<+79263842897]
16-дек-2013 11:44:19.015 [CM503025]: Call(C:3): Calling T:Fax:888@[Dev:sip:[email protected]:5100;user=phone] for L:3.1[Line:10000<<+79263842897]
16-дек-2013 11:44:18.906 [CM503027]: Call(C:3): From: Line:10000<<+79263842897 ("Храмов, Александр" <sip:[email protected]:5060>) to T:Fax:888@[Dev:sip:[email protected]:5100;user=phone]
16-дек-2013 11:44:18.906 [CM503004]: Call(C:3): Route 1: from L:3.1[Line:10000<<+79263842897] to T:Fax:888@[Dev:sip:[email protected]:5100;user=phone]
16-дек-2013 11:44:18.906 [Flow] Call(C:3): applied forwarding rule (Fwd[Away/AllCalls]) Extn:116 -> Fax:888
16-дек-2013 11:44:18.906 [CM505003]: Provider:[SIPNET - RU] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CommuniGatePro-callLeg/6.0.8k] PBX contact: [sip:[email protected]:5060]
16-дек-2013 11:44:07.093 Leg L:2.1[Extn] is terminated: Cause: BYE from PBX
16-дек-2013 11:44:07.093 [CM503008]: Call(C:2): Call is terminated
log:
