Does not close the line
Discussion in 'Windows' started by iopas, Nov 7, 2009.
  1. iopas
    Oct 26, 2009
    32
    I use the 3CX Phone from a remote site and everything works fine except one think. After the hung up, the line is still open. I use patton 4552 and I can see the line Led to blink. Is there any solution?
    Thanks.
  2. 888Mike
    Apr 27, 2009
    11
    Had this problem with an FXO gateway, not sure if the T1 gateways have similar settings but ensure "Loop-Break" is enabled in your T1 disconnect Settings.
  3. iopas
    Oct 26, 2009
    32
    Thank you,
    It is not possible to set loop-break parameter on a ISDN media gateway (SN4552) because digital telephony doesn't use this parameter.
  4. leejor
    11,116
    329
    Are there any other options within the gateway, for dropping the call, after,say, a predetermined amount of silence?
  5. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Try and find the correct Disconnection Tone for your Gateway here: http://www.3amsystems.com/
    Configure it correctly and it will disconnect calls correctly.
  6. iopas
    Oct 26, 2009
    32
    Sorry LeonidasG but I can not find the disconnect tone for any gateway in this site. There is only a World PSTN Database but without data for Greece.
    I have asked Patton for the right disconnect tone but I have not any answer yet.
    Why the problem faced only in remote extensions and not when I call mobile phones?
    How I will change the disconnect tone?
    Thank you.
  7. LeonidasG
    Nov 19, 2008
    1,557
    118
    If you needed the Greek Disconnection tone you should of just asked :p
    I mean my name does say: Leonidas after all.
    400@-30,400@-30;4(0.38/0.38/1+2)
  8. iopas
    Oct 26, 2009
    32
    Thank you Leonidas. I know that you are from Cyprus. :)
    An now, what can I do with disconnect tone that you gave me?
  9. LeonidasG
    Nov 19, 2008
    1,557
    118
    You can go in your Patton's settings and find a setting that either says: "Busy Tone" or "Disconnection Tone" and paste the Tone there. It might need some Re-Arranging because for some models the tone format has to be different.
  10. iopas
    Oct 26, 2009
    32
    ok, I will do it.
    I have the same problem when I call from a SIP provider (http://www.viva.gr). Is there any solution?
    Thanks.
