does skype have to be installed?
Discussion in '3CX Phone System - General' started by aftermarket, Aug 11, 2010.
  1. aftermarket
    May 13, 2009
    84
    does skype have to be installed notiched that theres a skype gateway in the 3cx control panel which made me think skype doesnt have to be installed any more?
  2. richardcrabb
    Jan 4, 2009
    Yes it does. The computer must also have audio otherwise Skype will not run. There are good instructions from 3CX that explain how to get the gateway up and running.
    Kind regards
    Richard Crabb
    http://www.dorsetphonesystems.com
