Does the mic auto gain?
Discussion in 'Windows' started by dsummer, Jan 10, 2011.
  1. dsummer
    Dec 6, 2010
    13
    Does 3CXPhone auto gain the mic? In a few successful calls, sometimes the recipient cannot hear me loud enough. It's afterwards that I notice the mic level is set to low Windows internal value instead of "63".
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    The mic volume setting is directly linked to Windows's mic volume slider in your sound settings.
    Increasing/decreasing mic from windows will directly affect your mic volume on the 3CX VoiP phone.
  3. dsummer
    Dec 6, 2010
    13
    Ok, thanks!
    One way to find your optimal mic level is to launch Skype and Windows mic properties, enable "Automatically adjust microphone settings" in Skype, say a few things and observe the value/slider in mic properties. Jot it down and set the level after you quit Skype.
