Domain versus Proxy
Discussion in '3CX Phone System - General' started by darryla, Oct 11, 2007.
  1. darryla
    Oct 11, 2007
    30
    I'm confused about the difference between a SIP proxy and the domain? I'm trying to setup X-Lite to work with 3CX. If I leave the proxy set to "target domain" it works.
    So what's the proxy do?
  2. LORD ORION
    Jul 23, 2007
    39
    The proxy is resposible for setting up the call between end points.
    http://en.wikipedia.org/wiki/Session_Initiation_Protocol
  3. darryla
    Oct 11, 2007
    30
    How do I know if I need to set one up?
    What I mean is, I'm having problems. So what does the Proxy buy me?
  4. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Your 3CX server is the proxy.
  5. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    My X-Lite is setup the same way and never had to change. Care to explain what sort of problems you are experiencing? It probably has nothing to do with this setting. If the problems are related to external extension use include info on your 3CX setup and port forwarding currently in place please.
