Don´t use 1.1.6.44 Firmware on GXP-2020 (Workaround found)
Discussion in '3CX Phone System - General' started by silentfun, Jan 3, 2009.
  1. silentfun
    silentfun Member
    Dec 11, 2006
    364
    Don´t use 1.1.6.44 Firmware on GXP-2020 it is pure horror.
    not getting ip by dhcp
    freezing
    with fixed ip it don´t register account 1 (all other he register)
    to get back you have to put in fixed ip and downgrade it best to 1.1.6.16
    if the account 1 allready don´t register u have to reset factory defaults -> config ->Factory Reset -> (enter MAC) push softkey OK
    shame on you Grandstream
    shame on me for update all phones at the same time - ( all release before i test over a week before i updated the other phones)
    hope this will help you
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    Re: Don´t use 1.1.6.44 Firmware on GXP-2020
    the problem is solved
    the not getting a ip with 1.1.6.44 Firmware is solved#
    it is depending on QLayer 2 QoS - if you put in value 6
    same problem whit some other firmware
    if the network don´t start you can not programm it via brouwser but manual from phone
