don´t works outgoin calls to numbers but works to nic names
Discussion in '3CX Phone System - General' started by pgberm, Aug 11, 2009.
  1. pgberm
    Aug 11, 2009
    Hi, I have the following matter
    when i put a land phone number I can´t do work the system but when I put a nic mane from Skype works perfectly.
    I atthach the log file:
    12:17:57.685 [CM503008]: Call(18): Call is terminated
    12:17:57.685 [CM503015]: Call(18): Attempt to reach <sip:91149416596@192.168.150.156:5060> failed. Reason: Busy
    12:17:57.685 [CM503003]: Call(18): Call to sip:1149416596@127.0.0.1:6060 has failed; Cause: 486 Busy Here; from IP:127.0.0.1:6060
    12:17:57.685 [CM505002]: Gateway:[ibcargentina01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.7919.0] Transport: [sip:127.0.0.1:5060]
    12:17:57.685 [CM503002]: Call(18): Alerting sip:10001@127.0.0.1:6060
    12:17:57.466 [CM503024]: Call(18): Calling PSTNline:1149416596@(Ln.10001@ibcargentina01)@[Dev:sip:10001@127.0.0.1:6060]
    12:17:57.451 [CM503004]: Call(18): Route 1: PSTNline:1149416596@(Ln.10001@ibcargentina01)@[Dev:sip:10001@127.0.0.1:6060]
    12:16:34.826 [CM503008]: Call(16): Call is terminated
    12:16:34.826 [CM503015]: Call(16): Attempt to reach <sip:9pablobermudezibc@192.168.150.156:5060> failed. Reason: Busy
    12:16:34.826 [CM503003]: Call(16): Call to sip:pablobermudezibc@127.0.0.1:6060 has failed; Cause: 486 Busy Here; from IP:127.0.0.1:6060 (here I receive the call)12:16:26.451 [CM505002]: Gateway:[ibcargentina01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.7919.0] Transport: [sip:127.0.0.1:5060]
    12:16:26.451 [CM503002]: Call(16): Alerting sip:10001@127.0.0.1:6060
    12:16:26.232 [CM503024]: Call(16): Calling PSTNline:pablobermudezibc@(Ln.10001@ibcargentina01)@[Dev:sip:10001@127.0.0.1:6060]
    12:16:26.216 [CM503004]: Call(16): Route 1: PSTNline:pablobermudezibc@(Ln.10001@ibcargentina01)@[Dev:sip:10001@127.0.0.1:6060]
    12:16:26.201 [CM503010]: Making route(s) to <sip:9pablobermudezibc@192.168.150.156:5060>
    12:16:26.201 [CM505001]: Ext.6501: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.150.156:5060]
    12:16:26.185 [CM503001]: Call(16): Incoming call from Ext.6501 to <sip:9pablobermudezibc@192.168.150.156:5060>
    12:16:13.076 [CM503008]: Call(15): Call is terminated
    I´m running all this on:
    Windows 2003 web server edition
    3cx 7,1
    Gateway for skype last version no beta.
    AMD 64bit X2
    2Gb Ram
    500gb HD
    Thank in advance.
    Regards,
    Pablo
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,477
    67
    Hi, Pablo
    I think this is the most common issue found until now :mrgreen:
    To dial phone numbers using Skype, there are two conditions REQUIRED:
    - have Skype credit
    - phone number SHOULD contain country code (00xx)
    Therefore, in your case, supposing you have SK as outbound rule, skypefriend Skype account and 99999999 phone number:
    - calling SKskypefriend will work
    - calling SK99999999 will not work, should be SK00xx99999999, where 00xx is the country code where 999999999 is located.
    Hope it helps
    Regards
    vali
  3. pgberm
    Aug 11, 2009
    Hi Vali! thank very much for you quick assist.
    Yes it´s fault, I trie with country code(54) and city Code(11) but doesn´t work, I attach the log for your review
    15:46:46.728 [CM504008]: Fax Service: registered as sip:8888@192.168.150.156:5060 with contact sip:8888@192.168.150.156:5100;user=phone
    15:46:18.244 [CM503008]: Call(5): Call is terminated
    15:46:18.228 [CM503015]: Call(5): Attempt to reach <sip:905401149416596@192.168.150.156:5060> failed. Reason: Busy
    15:46:18.228 [CM503003]: Call(5): Call to sip:05401149416596@127.0.0.1:6060 has failed; Cause: 486 Busy Here; from IP:127.0.0.1:6060
    15:46:18.228 [CM505002]: Gateway:[ibcargentina01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.7919.0] Transport: [sip:127.0.0.1:5060]
    15:46:18.228 [CM503002]: Call(5): Alerting sip:10001@127.0.0.1:6060
    15:46:18.010 [CM503024]: Call(5): Calling PSTNline:05401149416596@(Ln.10001@ibcargentina01)@[Dev:sip:10001@127.0.0.1:6060]
    15:46:17.978 [CM503004]: Call(5): Route 1: PSTNline:05401149416596@(Ln.10001@ibcargentina01)@[Dev:sip:10001@127.0.0.1:6060]
    15:46:17.963 [CM503010]: Making route(s) to <sip:905401149416596@192.168.150.156:5060>
    15:46:17.963 [CM505001]: Ext.6501: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.150.156:5060]
    15:46:17.963 [CM503001]: Call(5): Incoming call from Ext.6501 to <sip:905401149416596@192.168.150.156:5060>
    15:46:03.416 [CM503008]: Call(4): Call is terminated
    15:46:03.416 [CM503015]: Call(4): Attempt to reach <sip:9541149416596@192.168.150.156:5060> failed. Reason: Busy
    15:46:03.416 [CM503003]: Call(4): Call to sip:541149416596@127.0.0.1:6060 has failed; Cause: 486 Busy Here; from IP:127.0.0.1:6060
    15:46:03.416 [CM505002]: Gateway:[ibcargentina01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.7919.0] Transport: [sip:127.0.0.1:5060]
    15:46:03.416 [CM503002]: Call(4): Alerting sip:10001@127.0.0.1:6060
    15:46:03.197 [CM503024]: Call(4): Calling PSTNline:541149416596@(Ln.10001@ibcargentina01)@[Dev:sip:10001@127.0.0.1:6060]
    15:46:03.182 [CM503004]: Call(4): Route 1: PSTNline:541149416596@(Ln.10001@ibcargentina01)@[Dev:sip:10001@127.0.0.1:6060]
    15:46:03.166 [CM503010]: Making route(s) to <sip:9541149416596@192.168.150.156:5060>
    15:46:03.166 [CM505001]: Ext.6501: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4526.0] Transport: [sip:192.168.150.156:5060]
    15:46:03.150 [CM503001]: Call(4): Incoming call from Ext.6501 to <sip:9541149416596@192.168.150.156:5060>
    15:43:17.760 [CM503008]: Call(3): Call is terminated
    thank for all and I hope for a new version that repair the bug
    Best Regards,
    Pablo
  4. Vali_3CX
    Dec 12, 2008
    1,477
    67
    Hi, Pablo
    There is not a bug to be fixed, believe me :mrgreen:
    Let's have a look, together, at the logfile you posted:
    1 - Incoming call from Ext.6501 to <sip:9541149416596...
    2 - Calling PSTNline:541149416596@...
    Well, these two lines shows that the outbound rule is 9, and the number you want is 541149416596. Since there is no 00 in front of it, obviously you get
    3 - Attempt to reach <sip:9541149416596. failed. Reason: Busy
    The same case for 905401149416596 - 05401149416596. I don't know, but for all three countries I'm dialing usually, the phone number should start with 00, two zeros - while on your case is only one.
    To be sure, do the following test - open a standalone Skype and call from it 541149416596 and 05401149416596, respectively. If you don't have credit Skype will tell you. If the number is wrong, it again it will tells you - everytime Skype is unable to make the call, you will get a "...failed. Reason: Busy" on your sip phone.
    Please try this and tell me how is going.
    Regards
    vali
  5. pgberm
    Aug 11, 2009
    incleible! yes! you are rigth! my skype client reconize my country and never need to put "0054" in front any number! It´s working!!! now I pay for this solution.
    Thank you very much Vali!!!
