don't get it started
Discussion in '3CX Phone System - General' started by fabianus, Nov 6, 2007.
  1. fabianus
    Nov 6, 2007
    15
    Hello !
    I just did the setup of 3CX (free version). I created 2 extensions and tried to connect with the callassistant and with x-lite. In both cases I got the error "Error. Server unreatable".
    I am sure about the IP, the extention number and the Pin. I tried it on the machine that holds the 3CX server and on another machine and on both I disabled the windows firewall.
    Thanks a lot for any help to get this work!
    Regards,
    Fabianus
  2. fabianus
    Nov 6, 2007
    15
    Here are the logs :
    Time Function Message
    16:47:07.858 CallMgr::Initialize [CM000002] *!* Failed to initialize SIP stack!
    16:47:07.808 gt;>:Failed to create transport: V4 UDP 5060 on ANY
    16:47:07.728 gt;>:[ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] already in use
    16:47:07.698 CallMgr::Stack::Initialize [CM106000] ** Adding transports **
    16:47:07.629 CallMgr::Initialize [CM100003] ** Initializing SIP stack **
    16:47:07.629 CallMgr::Initialize [CM100002] Default Local IP address: 164.0.1.101:5060
    16:47:06.490 CallMgr::Initialize [CM100001] Version: 3.1.2434.0
    16:47:06.480 CallMgr::Initialize [CM100000] Start 3CX PhoneSystem Call Manager
    16:47:06.480 LoadLicenceInfo [CM100008] Licence loading error
    The "Failed to initialize SIP stack!" seems to be the reason. Any idea what I could do?
    Thanks a lot for any hint!
    Regards,
    Fabianus
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    You're running something that sits on SIP port 5060. It is not possible. You should change port either for that application, or for 3CX PBX
  4. fabianus
    Nov 6, 2007
    15
    Hi archie - thanks a lot for this advice, it solved my problem.
    Best regards,
    Fabianus
    PS Do you have any idea concerning this second problem ? :)
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/3cx-extensions-do-not-hear-voice-of-incoming-calls-2933/
