Dont know how to configure firewall
Discussion in '3CX Phone System - General' started by patrickrivard, Jun 4, 2008.
  1. patrickrivard
    patrickrivard New Member
    May 29, 2008
    100
    We have added a VOIP line and it appears as "Registered" (Green) but we cannot make any calls through it...
    When we do the "Firewall Test" it fails everytime with error 4 and 10.
    We have talked to a 3CX reseller in our area but they can't figure out what' wrong...
    We have followed all the Port Mapping instruction in the Manual, and read all we could find on the subject but with no Luck.
    If anyone can help we would greatly appreciate it.
  2. nitup
    May 16, 2008
    16
    Re: Call on VOIP does not work
    You would be more lucky if provide at least model of router, brief description of network topology, provider name, etc. Logs also could be helpful.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,914
    221
    If the firewall check fails your firewall is not correctly configured. You will have to do that first.
  4. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    Have a look at this page (http://www.3cx.com/support/firewal-checker.html), it describes the errors reported by the firewall checker.
    When testing different routers, one of them (a D-Link one) and a firewall/router on a computer (pfSense v1.2) gave me an error 10 in the firewall checker. This is because the firewall is in symmetric NAT mode, you need to have static NAT mappings. In the D-Link I had, I needed to enable gaming mode to correct this. With pfSense, I needed to create a rule and put the static mapping on.
    If you are currently in symmetric NAT, your router probably has an option for changing this.
    Can you provide the informations requested by "nitup"? They will help us helping you out!
  5. thomasz
    May 20, 2008
    10
    I had the same problem, but I'm not sure how I have solved the problem.
