Door Entry Phone
Discussion in '3CX Phone System - General' started by AlexDBarrett, Aug 1, 2017.
  1. AlexDBarrett
    Jan 25, 2011
    71
    9
    I have tried the MOSHI unit with an on premise installation however this will not provision to a Cloud system, insufficient setting features on phone.
    Can anyone suggest a unit which is IP and registers/provisions to 3CX when in the Cloud?
    I am using GCS.
