Door Entry - Video Call typing DTMF codes
Discussion in '3CX Phone System - General' started by Saqqara, Mar 1, 2018.
  1. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    877
    135
    We have an 2N door entry system which has video call function, Using the windows 3CX client we are able to answer the call, see the video and have an two way conservation.
    What we have not worked out, how to dial dtmf codes to open the door - can someone help
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Not sure of the question nor which model of 2N device. Are you asking which code, which DTMF, which switch setting, etc? 2N has a faq that may have many of the answers depending on model.
    The softphone also has a DTMF setting as some of the 2N products will work with all 3 methods whereas some only inband and sip-info.
  3. Saqqara
    Mar 12, 2014
    877
    135
    The question is to do with the 3CX client app, when answering a video call how do we type dtmf codes within the 3CX client - have not been able to work this out
    The door system is working fine, and setup with dtmf codes (works fine using a desk phone)
  4. nmnat
    Mar 1, 2018
    5
    I deployed something very similar and it comes down to just punching numbers during an active call.
    Iirc it is also possible to have the relais triggered just by calling the extension itself, depending on your setup this might be an option.
