Door phone/access control
Discussion in '3CX Phone System - General' started by Nebula, Apr 21, 2008.
  1. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Can anyone think of a reason why the Kalika Ulydor UC1 ( http://www.kalika.co.uk/ulydor.asp?id=7 ) should not work with an analogue TA on the 3CX.
    The UC1 is an analogue PBX enabled doorphone/access control module. When the call button is pressed it rings a pre-programmed extension/ring group, when answered the visitor has 2 way speech with the answering extension, the answering extension can then press a key sequence to release the door lock via a relay built into the UC1.
    May seem like a dumb question but this option looks too easy to be true so I am sure I am missing something.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    I think it's worth of trying to connect that device thru ATA and register it as an extension. I can not guarantee that it will allow you to open the door (by the way, how it is instructed to open? DTMF sequence?), but two way conversation you should get right out of the box.
  3. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Thanks for the reply. Yes it is a DTMF sequence, providing this will pass through the ATA it should work.
  4. h2009
    h2009 Member
    Mar 15, 2008
    447
    I was just wondering how much does that unit cost? I might replace units with thoses if it works :)
  5. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    They are generally being offered for sale in UK for around £125 +VAT
  6. Arnaud
    Nov 23, 2007
    43
    Interesting, I'll have a look for this, to extend the possibility from just speaking with the person at the door, to actually being able to open the door.
    For me the priority is to be able to communicate with people at a remote door, so I can tell them to go to a different door.
    At the moment I'm using a Cisco 7940 with broken off-hook switch (if you're lucky you find them cheap at Ebay). Soldered a wire on the message button to bring it to the external doorbell, as well as bringing the speaker and microphone outside.
    I've configured the phone to dial a ring-group number when the message button is pushed.
    At the outside of the door, I build the microphone and the speaker in an old external panel. Works well.
    Obviously you could do something similar with other phone with speaker-phone capabilities.
  7. sexyfoxes
    Apr 28, 2008
    Leadtek has great SIP devices as door phone, sip ip camera, video phone, and mmPBX (IP PBX with video support)
    NCP-3680
    http://www.leadtek.com/eng/video_surveillance/overview.asp?lineid=10&pronameid=343
    It is not only SIP ip camera, but also Intenet IP phone, Internet intercom, Internet door phone, and internet care phone for caring people.
    SIP
    IP camera
    http://www.leadtek.com/eng/video_surveillance/default.asp?lineid=10&seriesid=51
    SIP
    Video Phone
    http://www.leadtek.com/eng/videophone/default.asp?lineid=7&seriesid=30
    SIP
    http://www.gvscnet.net/gvsc_mm_pbx.html
    apollo@leadtek.com.tw
