Door phone for 3CX system?
Discussion in '3CX Phone System - General' started by h2009, Apr 2, 2008.
  1. h2009
    h2009 Member
    Mar 15, 2008
    447
    Hi there im looking to replace my door phone system Its current joint with my ISDN system (which has now been replaced for 3CX) and i was using these door phones KX-T30865: http://www.twacomm.com/catalog/model_KX-T30865.htm?sid=D2C5752E6B6F05856997094263EA06D8 - but of course they dont work. Is there any that do work with 3CX? Ideally wireless or something that can use RJ11 cable to transmit data?! to talk to the person at the door?
    Thank you
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    Would thing work with 3CX -http://www.vikingelectronics.com/products/view_product.php?pid=385#
  3. ess
    ess New Member
    Jun 8, 2007
    133
    The other day there were some posts about some CyberData VOiP paging products.
    Checking out their website, I found this door/intercom device:
    http://www.cyberdata.net/products/voip/voip-intercom.html
    Let us know how things go in your voip intercom application.
    *edit I noticed it says coming soon on the product page. It might be worth contacting them. Although the other product posted above looks promising too.
  4. h2009
    h2009 Member
    Mar 15, 2008
    447
    Ok i think i've got something http://www.manicphones.co.uk/Product/ID201
