Door phone help
Discussion in '3CX Phone System - General' started by nterrell, Feb 19, 2015.
  1. nterrell
    Feb 19, 2015
    8
    Hi There,
    I am using an Analog Door Phone which is connected to a Patton 4118 (model SN4118/4JS4JO/EUI), I need the door phone to call a ring group once someone takes it off hook. Can anyone point be in the right direction on how to configure the 4118/3cx to do that, I have been scratching my head reading the configuration manual of the patton but I am not sure of my next steps after I configure the FXS port with a 3cx extension.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    If not mistaken, the Patton you have is a both a FXO and FXS device. You need to set up the door phone as an extension which means it needs to be connected to one of the Patton FXS ports. The FXS port is then set up as an extension on the 3CX system. The door phone is then programmed such that when someone activates the dial sequence, it dials the ring group extension established in 3CX for the purpose.
  3. leejor
    10,835
    294
    To do what you want, the FXS ports has to dial (send) a preprogrammed number (of the ring group) when the caller (door phone) goes off-hook (hotline feature). This generally requires that the ATA has some sort of internal dialplan (digit pre-screening/manipulation) capability. I have not used the Patton units, so I can't say one way or the other if they are capable of this. I know that many (most?) of the Cisco/Linksys ATA's do have this feature, something like a SPA-2102, or even a PAP2, which would be in the lower cost range if you had to purchase another device. There may also be devices from other manufacturers.
    You might check with Patton, or on the Patton forum, if another forum member here doesn't put forward a suggestion.
  4. nterrell
    Feb 19, 2015
    8
    Thanks, I have reached out to Patton support, if they are able to help me I will post my config here for other in the same situation.
  5. nterrell
    Feb 19, 2015
    8
    Patton support was awesome and was able to help me. So I am attaching my config that allows FXS Port 0/0 to auto dial a call queue on 3cx, basically FXS 0/0 is mapped to extension 6001, which is set to dial the queue I setup which is 8001. This should work for any Patton 4110, Patton 4114 or Patton 4118.
    Code:
    # For SN-4118 8-port FXS
    # Supported firmware versions R6.x
    # Author: Kevin Attard Compagno
    # Contact: kevin@3cx.com
    timer CONFIG_UPDATE now + 2 minutes every 10 minutes "provisioning execute CONFIG"
    webserver port 80 language en
    sntp-client
    system
    ic voice 0
    low-bitrate-codec g729
    profile ppp default
    profile call-progress-tone defaultDialtone
    flush-play-list
    play 1 1000 350 -13 440 -13
    profile call-progress-tone defaultAlertingtone
    flush-play-list
    play 1 1000 440 -19 480 -19
    pause 2 3000
    profile call-progress-tone defaultBusytone
    flush-play-list
    play 1 500 480 -24 620 -24
    pause 2 500
    profile call-progress-tone defaultReleasetone
    flush-play-list
    play 1 250 480 -24 620 -24
    pause 2 250
    profile call-progress-tone defaultCongestiontone
    flush-play-list
    pause 2 250
    profile tone-set default
    profile voip default
    codec 1 g711alaw64k rx-length 20 tx-length 20
    codec 2 g711ulaw64k rx-length 20 tx-length 20
    codec 3 g729 rx-length 20 tx-length 20
    fax transmission 1 relay t38-udp
    modem transmission 1 bypass g711alaw64k rx-length 20 tx-length 20
    profile pstn default
    play 1 1000
    pause 2 4000
    profile sip default
    no autonomous-transitioning
    profile aaa default
    method 1 local
    method 2 none
    profile provisioning CONFIG
    destination configuration
    location 1 tftp://$(dhcp.66)/${system.mac}
    activation reload graceful
    context ip router
    interface IF_IP_LAN
    ipaddress 192.168.100.61 255.255.255.0
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
    context cs switch
    no digit-collection timeout
    routing-table called-e164 RT_DIGITCOLLECTION
    route .T dest-interface IF_SIP_3CX MT_EXT_TO_NAME
    routing-table called-e164 RT_TO_FXS
    route 6001 dest-interface IF_FXS_00
    route 6003 dest-interface IF_FXS_01
    route 6004 dest-interface IF_FXS_02
    route 6005 dest-interface IF_FXS_03
    routing-table called-e164 RT_from_FXS00
    route default dest-interface IF_SIP_3CX MAP8001
    mapping-table calling-e164 to calling-name MT_EXT_TO_NAME
    map 6001 to "Red Phone"
    map 6003 to "Analog 3"
    map 6004 to "Analog 4"
    map 6005 to "Analog 5"
    mapping-table called-e164 to called-e164 MAP8001
    map default to 8001
    interface sip IF_SIP_3CX
    bind context sip-gateway GW_SIP_ALL_EXTENSIONS
    route call dest-table RT_TO_FXS
    remote 192.168.100.235 5060
    local 192.168.100.235 5060
    trust remote
    interface sip IF_SIP_AUTODIAL
    route call dest-interface IF_FXS_00
    address-translation outgoing-call from-header user-part fix 8001 host-part call
    trust remote
    interface fxs IF_FXS_00
    route call dest-table RT_from_FXS00
    subscriber-number 6001
    interface fxs IF_FXS_01
    route call dest-table RT_DIGITCOLLECTION
    subscriber-number 6003
    interface fxs IF_FXS_02
    subscriber-number 6004
    interface fxs IF_FXS_03
    subscriber-number 6005
    context cs switch
    no shutdown
    authentication-service AS_ALL_EXTENSIONS
    realm 1 3CXPhoneSystem
    username 6001 password redacted
    username 6003 password redacted
    username 6004 password redacted
    username 6005 password redacted
    location-service LS_ALL_LINES
    domain 1 192.168.100.235
    identity-group default
    authentication outbound
    authenticate 1 authentication-service AS_ALL_EXTENSIONS
    registration outbound
    registrar 192.168.100.235 5060
    lifetime 300
    register auto
    identity 6001 inherits default
    identity 6003 inherits default
    identity 6004 inherits default
    identity 6005 inherits default
    interface LAN
    bind interface IF_IP_LAN context router port 5060
    bind location-service LS_ALL_LINES
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    bind interface IF_IP_LAN router
    no shutdown
    port fxs 0 0
    use profile fxs us
    encapsulation cc-fxs
    bind interface IF_FXS_00 switch
    no shutdown
    port fxs 0 1
    use profile fxs us
    bind interface IF_FXS_01 switch
    no shutdown
    port fxs 0 2
    use profile fxs us
    bind interface IF_FXS_02 switch
    no shutdown
    port fxs 0 3
    use profile fxs us
    bind interface IF_FXS_03 switch
    no shutdown
