Door phone ring based on time settings. ? suggestions welcomed
Discussion in '3CX Phone System - General' started by AGidi, Mar 5, 2018.
  1. AGidi
    Jun 30, 2017
    49
    6
    Hello
    We have a location with 2 Fanvil door phones. They currently ring at reception 24/7. We need to route them to a different ring group based on the office hours. Sounded simple....
    We had a cyberdata door phone before, those had on board scheduling, but they died out too frequently.
    This FanvilT20 does not support hour/based dialing.
    How can we tackle this on the PBX?
    Since it's an extension, we can´t use inbound rules.
    all ideas and suggestions are welcomed.
    11,071
    323
    I'm going to assume that the door phone "auto dials" a predetermined extension number when activated. Have it call a new "Dummy extension", you create. Use the call forward/time of day routing, in that extension, to determine when, and where the calls are to go.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,248
    202
    As above, create a dummy extension and use the forwarding rules - 'Automatically switch status to available during office hours'
  4. AGidi
    Jun 30, 2017
    49
    6
    Hello, yes it auto dials an ext group.
    I appreciate the idea of the dummy extension, just one issue, how do you handle the extension being not registered?
    We get stuck at " If I am busy or my phone is unregistered, forward calls to: "
    This runs before the time conditions or the exceptions.
    :confused:
  5. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    One option would be to create a CFD application. Forward calls from the Fanvil to the CFD Extension. Then the CFD can use whatever logic you want. You could have it do different things based on office hours, or day of week, etc. You control the logic of when/where the call is forwarded in the CFD application.
    AGidi likes this.
  6. Saqqara
    Mar 12, 2014
    1,248
    202
    CFD is a good option, need Pro or Enterprise version
    To overcome the extension not being registered, you can set the extension up on a mobile which will registered the phone then you can delete the config on the mobile and it will still be registered.
    AGidi likes this.
  7. AGidi
    Jun 30, 2017
    49
    6
    ahh good trick on the mobile.
    We will try CFD, never used it, good time to learn i guess.
    thanks I will keep you updated, thanks for the prompt replies. much appreciated
  8. leejor
    11,071
    323
    Set the "dummy" extension to enable PUSH, it will always show as registered.
  9. Saqqara
    Mar 12, 2014
    1,248
    202
