Doorphone
Discussion in '3CX Phone System - General' started by dlazure, Feb 5, 2013.
  1. dlazure
    Nov 5, 2012
    65
    Anyone installed some doorphone ? Do we need to connect it as an analog station ?
  2. snowsam
    May 26, 2011
    79
    I'm not sure where you are located, but when I researched them late last fall for a USA install, I had a hard time finding a SIP door device that was available in the USA market. I considered analog, but then in the end we installed a wireless doorbell instead.
  3. dlazure
    Nov 5, 2012
    65
    i am located in canada, thaks i will look into sip doorphone
  4. leejor
    10,868
    304
    This request has come up before. Do a search through the forum, I seem to recall someone providing some links to a system that they had used/recommended. If you are talking about a multi-tenant (apartment building type system), then it might be less expensive to go with a conventional analogue unit and an ATA.
  5. dlazure
    Nov 5, 2012
    65
    Im talking about a doorphone for a loading dock not for apartments
  6. m1singh
    Feb 12, 2013
    Try this
    http://www.thetelecomspot.com/algo-8028-sip-compatible-doorphone-intercom.html
  7. elytronic
    Jun 15, 2012
    27
    2N Helios should work well. Video should also work with both Grandstream GXV3140 and Cisco SPA525. I plan to test it soon.
  8. snowsam
    May 26, 2011
    79
    Attached is my rough research from months back...
  9. netswork
    netswork Active Member
    Mar 11, 2011
    577
    The 2n phones are the nicest looking ones I have seen. Valcom makes good products, we use their paging equipment but have never used one of their door phones.
  10. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    I don't know how true ... but the UK Sales guy for CyberData has told me that their SIP door entry unit is 3CX compatible. Looks to be a good strong unit with or without an entry control keypad ...
    http://www.cyberdata.net/products/voip/digitalanalog/intercomkeypadv3/index.html
    Manuals and userguides are pretty comprehensive and straight-forward. looks to be easy enough to set up on 3CX.
    best regards ...
