Dot Net Library
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Aug 27, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    When you call to a .Net assembly, does the object you're instantiating have to have a constructor with no parameters?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Yes, currently we need to create a new instance of the object (using a parameter less constructor), invoke the method on it, and let it be garbage collected.
    If you need to reuse an object or create it using parameters, you may for example create a singleton which has a reference to it, and use the singleton as a proxy.
    I'm pretty sure that in future versions of the VAD this feature will be added...
