double digital receptionist
Discussion in '3CX Phone System - General' started by mckey415, Oct 4, 2007.
  1. mckey415
    Jun 27, 2007
    24
    hi!
    i have the following problem. i have 3cx installed and configured with dlink dvg 3004s media gateway connecting it to panasonic kx tda 200 pbx. in 3cx i created a digital receptionist and configured the pstn lines to forward all incoming calls this digital receptionist. now from my desk phone, connected to panasonic pbx, i dial the number of the line dlink is connected to and first i hear the "Please dial extention number (and then something in chineese)" message then i dial any 3cx extension number and then hear the voice message from the digital receptionist that i created, then i dial the 3cx extension and the call is forwarded correctly.
    so is it behaviour by design or some kind of bug?
  2. mckey415
    Jun 27, 2007
    24
    i investigated this problem i little bit further. seems that it's a dlink biult in ivr. anybody knows how to disable it?
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please try to config DLINK gateway hotline to 3CX extension or DR number. It works at DLINK DVG-7022S gateway.
  4. mckey415
    Jun 27, 2007
    24
    yes, i already solved this problem and it really was about configuring hot lines
