Download 3cxconfig file
Discussion in '3CX Phone System - General' started by adrianc, Jan 20, 2016.
  1. adrianc
    Sep 4, 2015
    20
    Is there a way you can download the extension 3cxconfig file from the server?
    I've a customer that has no working email so I can't send the welcome email from 3CX.
  2. JMHenson
    Jan 20, 2016
    You could set the extension's email to your email address, send the email to yourself, download the resulting file and Dropbox/FTP/whatever the file to them.
  3. adrianc
    Sep 4, 2015
    20
    In this case the 3CX server doesn't have access to a mail server / or public relay.
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    I think you can use this as a work-around
    On the server go to:
    C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\xxxx\TcxProvFiles\
    Then select the desired config file, copy to a different folder and rename the extension from .xml into .3cxconfig
    Now you can use it as config file for your extension.
    Hope this helps.
