DR - Extention Breakout
Discussion in '3CX Phone System - General' started by tomlinm, Dec 18, 2008.
  1. tomlinm
    Oct 27, 2007
    20
    Hi Everyone
    I have trawled through the forums and cant find the answer to this one.
    In previous versions, when a DR answers a call, its possible to enter any extention number and the call would direct to that extention...now, you receive a message "an error occured in the ivr session, sorry"
    Any ideas or is this now a limitation in V7
    Mark
  2. tomlinm
    Oct 27, 2007
    20
    Yes, clean install on Windows 2003 STD
    I did restore a backup created in V6, with settings etc but have also tried creating a new DR with the same results.
    Any ideas?
    Mark
  3. tomlinm
    Oct 27, 2007
    20
    Hi again
    Unsure of its relevance, but i have installed the call log reported tool, and that is showing that no calls have been made when i know they have?
    Mark
  4. tomlinm
    Oct 27, 2007
    20
    Hello
    A little more information for the pot
    The result is the same if the call comes in via a PSTN line or a VoIP (voiptalk.org) line, so totally removes and issues about a blocked port
    mark
  5. tomlinm
    Oct 27, 2007
    20
    Hello again
    short of uninstalling, re-installing and setting everything up from scratch....
    I have created a new VoIP provider, new Extention and new DR and the problem remains.
    any thoughts on this? will uninstalling make any difference
    Mark
  6. tomlinm
    Oct 27, 2007
    20
    The same happens when calling the DR from an extention...
    Also tried 1234 (voicemail) to drop out, same response
    mark
  7. Resolve
    Sep 19, 2007
    94
    Just a thought guys - is this the Free version or the Full version that is working/not working ?
    Tim
  8. Resolve
    Sep 19, 2007
    94
    -It should work on both.
    -It works on v7 paid version.
    Agreed it *should*...... :wink: .......
    Tim
  9. tomlinm
    Oct 27, 2007
    20
    Hi Guys
    This is the FREE version and a clean install, including settings reveals that it still doenst work and is perhaps a limitation?
    Many thanks
    Mark
  10. lotsu99
    Jan 1, 2008
    27
    I paid !!!!! but i have same problem ~~~~ It can't work !!!
  11. tomlinm
    Oct 27, 2007
    20
    I have just tried a clean install, on a test 2k3 server, setup extentions, lines and DR from start, with the 2 call key...
    same issues.
    Mark
  12. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Guys, we've recently found bug that causes that systems with 2,4 or 5 digits extensions doesn't handle direct transfer from DR properly. It is fixed already and will be available with next update. 3-digits long systems work OK.
  13. archie
    3CX Support
    Aug 18, 2006
    1,299
    Again and again, sorry, but I'm not authorized to announce any estimations :)
