DR picks up but no onhold music played
Discussion in '3CX Phone System - General' started by fishes, Feb 12, 2008.
  1. fishes
    Feb 11, 2008
    Hi, I have been tackling such a problem with DR. It picks up incoming calls but it does not play "prompt". I take a look at my server status and the only error message I can see is the following:
    07:12:50.180 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    07:12:49.184 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    07:12:48.181 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    07:12:47.185 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    07:12:46.184 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    07:12:45.188 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    07:12:44.187 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    07:12:43.191 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    07:12:42.190 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    07:12:41.181 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    Can anyone give me a hand where to start analyzing this problem?
    Thank you
    Fishes
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    did you open the ports on router/firewal?
    you need UDP 5060, 3478, 9000-9015
    and UDP ports 7000-7015 for internal calls.
    hope this help
  3. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    which version are you using?
  4. fishes
    Feb 11, 2008
    thanx to all for immediate replies.
    I have just installed 5.1 beta but I bumped into the problem mentioned above in the previous version too. The fact is that I have not checked my firewall for all needed ports. I am sure about 5060. I am going to check it.
    All works all right when calls are made inside of my network. I mean internal numbers such as 100,101,102, etc, etc !!!!
    I noticed this:
    - I make a call from outside through my Voip provider
    - DR picks up my call
    - no onhold music is heard
    - after pressing "0" for example to forward my call MediaServerReporting::Service falls
    I am going to check ports and let you know
    thanks a lot
    Fishes
  5. fishes
    Feb 11, 2008
    well, I have checked all ports. There is no problem.
    I have not mentioned that I am running it on Windows Vista, Business Edition.
    Nonetheless, the call is pickud up by DR, no prompt is played and when forwarding the service keeps falling down. The last log I catched might help:
    08:19:27.911 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    08:19:26.910 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    08:19:25.907 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    08:19:24.901 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    08:19:23.930 MediaServerReporting::Service IVR not found on 127.0.0.1:5483
    08:19:22.892 MediaServerReporting::Service *** Connecting to [127.0.0.1:5483] ***
    08:19:22.892 MediaServerReporting::Service *** Disconnected from tucnak-office:5483/IVRServer at 127.0.0.1:5483 ***
    08:19:15.381 MediaServerReporting::DTMFhandler [MS211000] C:10.1: 82.119.243.23:57212 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
    08:18:45.652 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:800
    08:18:45.635 CallCtrl::eek:nLegConnected [CM503007]: Call(10): Device joined: sip:737378269@82.119.243.21:5060
    08:18:44.819 CallCtrl::eek:nLegConnected [CM503007]: Call(10): Device joined: sip:
  6. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    Has anyone fixed this music on hold problem yet???
    We are using V5.1.4393.0 with GXP2020 & 2010 plus 2000.
    All phones have the latest upgrades.
    ecwilson
  7. jspearso
    Aug 16, 2008
    8
    Has anyone come up with a soultion for this all ports on my router are enabled. but still no onhold music on my outside lines
  8. jspearso
    Aug 16, 2008
    8
    bump^^^^^^^
