Draytek 2800VG - Firewall
Discussion in '3CX Phone System - General' started by alex22alex, Jun 11, 2008.
  1. alex22alex
    Jun 11, 2008
    38
    Hello All,
    I am having a terrible time with getting the firewall on my Draytek router to play with 3CX. Even if i open the ports 3CX needs, setup the computer with a static ip and setup a port redirecting i still get an error 8 / 10 for the ports in the range 9000-9015. The other ports seem not to fail.
    Has anyone setup this or a similar draytek router with 3CX. Any tips ?
    Thanks Alex
  2. andrea
    May 31, 2008
    Hi Alex,
    your model have voice function and some port are redirect to itself.
    I don't kwnow if this is exactly your problem, but it's very common.
    You need to disable all voip service on router an redirect ports in NAT -> Port Redirection or NAT -> Open Ports for multiple.
    hope this help..
    Andrea
  3. alex22alex
    Jun 11, 2008
    38
    Perfect got it all sorted.
    Thanks Alex
