Nick_M
- Joined
- Aug 11, 2014
- Messages
- 24
- Reaction score
- 1
Hi All,
I have searched and read everything I can find re 3CX and Draytel, and it appears that some of you have successfully managed to set this up. I also see some had problems and then got connected but they don't say what they did to cure the problem!
So here is the problem:
I am trying to migrate our existing Draytel SIP Trunk from the Draytek IPPBX that we currently have, to a new 3CX installation (V12).
I have set the VOIP Provider as follows (copied from my working Draytek IPPBX Setup):
SIP Server hostname or IP: draytel.org
SIP Server Port: 5070
Outbound proxy hostname or IP: nat.draytel.org
Outbound proxy port: 5065
I then enter my draytel number into the External number, Authentication ID, Authentication password, and 3-Way authentication fields.
I set the inbound rule to dial my one test extension
I set the outbound rule as:
Calls starting with prefix =9
route: draytel trunk, strip digits=1
However...I cannot get the 3CX system to register with the Draytel service.
I get the following message:
Registration failed for: Lc:10000(@Draytel[<sipmysipid)@draytel.org:5070>]); Cause: Cause: 401 Unauthorized/REGISTER from 217.14.138.154:5065
I have done the firewall check and all passes
I have double checked my user id/password. I have tried substituting 5060 as server and proxy ports. I have tried removing the proxy details. Still wont register.
I am now at a loss!!
Can someone who has successfully implemented a Draytel registration advise as to the settings that worked for them? Currently we have 11 DID numbers registered with them so I don't want to have to change providers if I can help it!!
TIA
Nick
TIA
Nick
