Drop call constantly at 32 sec
Discussion in 'Windows' started by zic, May 9, 2016.
  1. zic
    zic
    Jan 15, 2016
    6
    Drop call (internal n external) constantly at 32 sec when using tunnel and only happened to windows soft-phone only. Anybody have this kind of problem before ? Fyi, 3cxv14 up to date with SP3 .
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    Although I am not sure what specifically is causing this, but 3CX Phone System drops a call after exactly 32 seconds if it does not receive an ACK message in that time after a call has been answered.
    Is anything on your system using port 5080? Did you change some port on the 3CX System to that port?
  3. kinetix
    Jan 7, 2010
    26
    I suspect you will find this is a firewall issue -
