Dropped Calls on Failed Transfers
Discussion in '3CX Phone System - General' started by ViperBorg, Jun 25, 2008.
  1. ViperBorg
    Jun 25, 2008
    7
    I have my Call Group set up to ring 2 extensions. If both do not answer, it's set to go directly to a voicemail box. Instead, it drops the call. Any ideas?
  2. ViperBorg
    Jun 25, 2008
    7
    My log by the way:
    Code:
    11:57:58.703  	Call::Terminate  	[CM503008]: Call(6): Call is terminated
    11:57:58.642 	Call::RouteFailed 	[CM503015]: Call(6): Attempt to reach [sip:800@127.0.0.1:5060] failed. Reason: No Answer
    11:57:48.227 	Extension::printEndpointInfo 	[CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Test Phone] Transport: [sip:192.168.2.2:5060]
    11:57:48.227 	CallCtrl::onAnsweredCall 	[CM503002]: Call(6): Alerting sip:100@99.139.126.94:5070;rinstance=696f8c0d69557267
    11:57:44.943 	CallCtrl::onSelectRouteReq 	[CM503004]: Call(6): Calling: RingAll800:100Ext.100101Ext.101@[Dev:sip:100@99.139.126.94:5070;rinstance=696f8c0d69557267, Dev:sip:101@192.168.2.103:5060;user=phone;transport=udp]
    11:57:44.622 	CallCtrl::onSelectRouteReq 	[CM503010]: Making route(s) to [sip:800@127.0.0.1:5060]
    11:57:43.931 	CallCtrl::onIncomingCall 	[CM503001]: Call(6): Incoming call from Ext.801 to [sip:800@127.0.0.1:5060]
    11:57:34.998 	CallCtrl::onLegConnected 	[CM503007]: Call(5): Device joined: sip:801@127.0.0.1:40600;rinstance=1b55d50a25788b33
    11:57:34.998 	LineCfg::getInboundTarget 	[CM503012]: Inbound office hours' rule for LN:10000 forwards to DN:801
    11:57:34.958 	CallCtrl::onLegConnected 	[CM503007]: Call(5): Device joined: sip:18472150100@63.214.44.25
    11:57:34.948 	Extension::printEndpointInfo 	[CM505001]: Ext.801: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX MakeCall helper] Transport: [sip:127.0.0.1:5060]
    11:57:34.948 	CallCtrl::onAnsweredCall 	[CM503002]: Call(5): Alerting sip:801@127.0.0.1:40600;rinstance=1b55d50a25788b33
    11:57:34.468 	CallCtrl::onSelectRouteReq 	[CM503004]: Call(5): Calling: Ext:Ext.801@[Dev:sip:801@127.0.0.1:40600;rinstance=1b55d50a25788b33]
    11:57:34.468 	CallCtrl::onSelectRouteReq 	[CM503010]: Making route(s) to [sip:801@192.168.2.2:5060]
    11:57:34.458 	Line::printEndpointInfo 	[CM505003]: Provider:[7027650793] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [MagicPacket] Transport: [sip:192.168.2.2:5060]
    11:57:34.458 	LineCfg::getInboundTarget 	[CM503012]: Inbound office hours' rule for LN:10000 forwards to DN:801
    11:57:34.297 	CallCtrl::onIncomingCall 	[CM503001]: Call(5): Incoming call from 18472150100@(Ln.10000@7027650793) to [sip:801@192.168.2.2:5060]
    11:57:34.187 	LineCfg::getInboundTarget 	[CM503012]: Inbound office hours' rule for LN:10000 forwards to DN:801
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    If it is about V6 - it is already fixed and will be available soon. Meanwhile you can just restart PBX server. As long as you do NOT modify ring group's settings - it should work.
  4. ViperBorg
    Jun 25, 2008
    7
    Okay. Thanks, Archie.
  5. wisecomputers
    wisecomputers New Member
    Apr 24, 2008
    126
    When will this be fixed, i need it ASAP. My client is going nuts about dropped calls.
  6. ViperBorg
    Jun 25, 2008
    7
    Yeah, it's getting on my nerves too.
  7. ViperBorg
    Jun 25, 2008
    7
    Except restarting does nothing to change it. Really need a working fix.
  8. ViperBorg
    Jun 25, 2008
    7
    Anything yet? Honestly?
