Dropped Calls - Registeration Attempts Delay
Discussion in '3CX Phone System - General' started by chrisjr, Oct 29, 2007.
  1. chrisjr
    Jan 23, 2007
    21
    We have been getting dropped calls at least 8-10 times a day. We will be talking to someone and then it will just disconnect the caller. Could this have anything to do with the registration attempts delay? Right now we have it set at 3,600 seconds which is the default setting
  2. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    We need more info- how long does it work before it drops, what phones are you using, are the extensions local or remote, can you post some logs?
  3. weebnuts
    Sep 13, 2007
    37
    yes as mentioned above, we need more info.
    I haven't had any dropped calls.
    are you using a gateway or a VOIP provider?
  4. chrisjr
    Jan 23, 2007
    21
    Logs and More Info
    I've changed my debugging mode to verbose and I've pasted the server log below. We are using Zingo as our VOIP provider and 3cx is running on a computer that is on the DMZ. We are not using a gateway
    11:54:18.085 StratLink::eek:nHangUp [CM104001] Call(15): Ext.102 hung up call; cause: BYE; from IP:192.168.2.15
    11:52:42.069 CallLegImpl::eek:nConnected [CM103001] Call(15): Created audio channel for Ext.102 (192.168.2.15:16432) with Media Server (192.168.2.50:7110)
    11:52:42.054 StratInOut::eek:nConnected [CM104005] Call(15): Setup completed for call from Ln:10000@Zingo to Ext.102
    11:52:39.335 CallConf::eek:nProvisional [CM103003] Call(15): Ext.101 is ringing
    11:52:36.569 StratLink::eek:nHangUp [CM104001] Call(13): Ext.101 hung up call; cause: BYE; from IP:192.168.2.14
    11:52:36.523 StratLink::eek:nHangUp [CM104001] Call(14): Ext.103 hung up call; cause: BYE; from IP:192.168.2.12
    11:52:34.148 MediaServerReporting::DTMFhandler [MS211000] Call(15) Ln:10000@Zingo: DTMF (RTP) from 207.218.174.156:52752 arrived. in-band DTMF tone detection is turned off.
    11:52:23.148 CallLegImpl::eek:nConnected [CM103001] Call(15): Created audio channel for Ln:10000@Zingo (207.218.174.156:52752) with Media Server (67.53.129.195:9028)
    11:52:23.116 CallConf::eek:nIncoming [CM103002] Call(15): Incoming call from 15405831613 (Ln:10000@Zingo) to sip:2622289970@67.53.129.195
    11:51:18.069 MediaServerReporting::RTPSender [MS104000] Call(14) Ext.103: (ACTIVE) RTP stream to 192.168.2.12:16480 restored.
    11:51:18.069 StratLink::eek:nHangUp [CM104001] Call(12): Ln:10000@Zingo hung up call; cause: BYE; from IP:69.25.48.83
    11:50:57.913 MediaServerReporting::RTPSender [MS004000] Call(14) Ext.103: (ACTIVE): Can't send RTP stream to 0.0.0.0:16480 destination unreachable
    11:50:55.273 CallLegImpl::eek:nConnected [CM103001] Call(14): Created audio channel for Ext.103 (192.168.2.12:16480) with Media Server (192.168.2.50:7104)
    11:50:55.257 StratInOut::eek:nConnected [CM104005] Call(14): Setup completed for call from Ln:10000@Zingo to Ext.103
    11:50:51.507 CallConf::eek:nProvisional [CM103003] Call(14): Ext.103 is ringing
    11:50:45.819 MediaServerReporting::DTMFhandler [MS211000] Call(14) Ln:10000@Zingo: DTMF (RTP) from 207.218.174.156:53772 arrived. in-band DTMF tone detection is turned off.
    11:50:37.132 MediaServerReporting::RTPSender [MS104000] Call(13) Ext.101: (ACTIVE) RTP stream to 192.168.2.14:16418 restored.
    11:50:36.913 CallLegImpl::eek:nConnected [CM103001] Call(14): Created audio channel for Ln:10000@Zingo (207.218.174.156:53772) with Media Server (67.53.129.195:9026)
    11:50:36.726 CallConf::eek:nIncoming [CM103002] Call(14): Incoming call from 16157409724 (Ln:10000@Zingo) to sip:2622289970@67.53.129.195
    11:50:27.429 MediaServerReporting::RTPSender [MS004000] Call(13) Ext.101: (ACTIVE): Can't send RTP stream to 0.0.0.0:16418 destination unreachable
    11:50:24.663 CallLegImpl::eek:nConnected [CM103001] Call(13): Created audio channel for Ext.101 (192.168.2.14:16418) with Media Server (192.168.2.50:7092)
    11:50:24.663 StratInOut::eek:nConnected [CM104005] Call(13): Setup completed for call from Ln:10000@Zingo to Ext.101
    11:50:12.038 CallConf::eek:nProvisional [CM103003] Call(13): Ext.103 is ringing
    11:50:06.929 MediaServerReporting::DTMFhandler [MS211000] Call(13) Ln:10000@Zingo: DTMF (RTP) from 207.218.174.156:53800 arrived. in-band DTMF tone detection is turned off.
    11:50:02.835 CallLegImpl::eek:nConnected [CM103001] Call(13): Created audio channel for Ln:10000@Zingo (207.218.174.156:53800) with Media Server (67.53.129.195:9024)
    11:50:02.804 CallConf::eek:nIncoming [CM103002] Call(13): Incoming call from 19786870999 (Ln:10000@Zingo) to sip:2622289970@67.53.129.195
    11:49:48.163 ListenConnect [CM114000] SL: connected DellOwner1:0/PHPExtension_0 at [DellOwner1]/PHPExtension_0
    11:49:46.413 CallLegImpl::eek:nConnected [CM103001] Call(12): Created audio channel for Ext.102 (192.168.2.15:16426) with Media Server (192.168.2.50:7086)
    11:49:46.413 StratInOut::eek:nConnected [CM104005] Call(12): Setup completed for call from Ln:10000@Zingo to Ext.102
    11:49:44.054 CallConf::eek:nProvisional [CM103003] Call(12): Ext.103 is ringing
    11:49:38.304 MediaServerReporting::DTMFhandler [MS211000] Call(12) Ln:10000@Zingo: DTMF (RTP) from 207.218.174.156:50786 arrived. in-band DTMF tone detection is turned off.
    11:49:29.054 CallLegImpl::eek:nConnected [CM103001] Call(12): Created audio channel for Ln:10000@Zingo (207.218.174.156:50786) with Media Server (67.53.129.195:9022)
    11:49:28.991 CallConf::eek:nIncoming [CM103002] Call(12): Incoming call from 17202837714 (Ln:10000@Zingo) to sip:2622289970@67.53.129.195
    11:49:26.663 CallMgr::DumThread::thread [CM000003] *!* Exception catched: unknown
    11:49:16.101 CallMgr::DumThread::thread [CM000003] *!* Exception catched: unknown
    11:49:14.382 StratLink::eek:nHangUp [CM104001] Call(11): Ln:10000@Zingo hung up call; cause: unknown
    11:49:01.569 CallMgr::DumThread::thread [CM000003] *!* Exception catched: unknown
    11:48:54.148 CallMgr::DumThread::thread [CM000003] *!* Exception catched: unknown
    11:48:45.335 CallMgr::DumThread::thread [CM000003] *!* Exception catched: unknown
    11:48:44.288 CallLegImpl::eek:nConnected [CM103001] Call(11): Created audio channel for Ext.102 (192.168.2.15:16424) with Media Server (192.168.2.50:7078)
    11:48:44.273 StratInOut::eek:nConnected [CM104005] Call(11): Setup completed for call from Ln:10000@Zingo to Ext.102
    11:48:38.288 CallConf::eek:nProvisional [CM103003] Call(11): Ext.101 is ringing
    11:48:32.491 MediaServerReporting::DTMFhandler [MS211000] Call(11) Ln:10000@Zingo: DTMF (RTP) from 207.218.174.156:53084 arrived. in-band DTMF tone detection is turned off.
    11:48:24.476 CallLegImpl::eek:nConnected [CM103001] Call(11): Created audio channel for Ln:10000@Zingo (207.218.174.156:53084) with Media Server (67.53.129.195:9020)
    11:48:24.444 CallConf::eek:nIncoming [CM103002] Call(11): Incoming call from 19786870999 (Ln:10000@Zingo) to sip:2622289970@67.53.129.195
    11:46:42.991 StratLink::eek:nHangUp [CM104001] Call(10): Ext.102 hung up call; cause: BYE; from IP:192.168.2.15
    11:45:28.694 CallLegImpl::eek:nConnected [CM103001] Call(10): Created audio channel for Ext.102 (192.168.2.15:16420) with Media Server (192.168.2.50:7070)
    11:45:28.679 StratInOut::eek:nConnected [CM104005] Call(10): Setup completed for call from Ln:10000@Zingo to Ext.102
    11:45:20.429 CallConf::eek:nProvisional [CM103003] Call(10): Ext.101 is ringing
    11:45:15.351 MediaServerReporting::DTMFhandler [MS211000] Call(10) Ln:10000@Zingo: DTMF (RTP) from 207.218.174.156:50398 arrived. in-band DTMF tone detection is turned off.
    11:45:09.601 CallLegImpl::eek:nConnected [CM103001] Call(10): Created audio channel for Ln:10000@Zingo (207.218.174.156:50398) with Media Server (67.53.129.195:9018)
    11:45:09.569 CallConf::eek:nIncoming [CM103002] Call(10): Incoming call from 12018392272 (Ln:10000@Zingo) to sip:2622289970@67.53.129.195
    11:41:20.944 StratLink::eek:nHangUp [CM104001] Call(9): Ln:10000@Zingo hung up call; cause: BYE; from IP:69.25.48.83
    11:39:35.906 CallLegImpl::eek:nConnected [CM103001] Call(9): Created audio channel for Ext.102 (192.168.2.15:16418) with Media Server (192.168.2.50:7062)
    11:39:35.906 StratInOut::eek:nConnected [CM104005] Call(9): Setup completed for call from Ln:10000@Zingo to Ext.102
    11:39:12.156 CallConf::eek:nProvisional [CM103003] Call(9): Ext.101 is ringing
    11:39:07.156 MediaServerReporting::DTMFhandler [MS211000] Call(9) Ln:10000@Zingo: DTMF (RTP) from 207.218.174.156:50620 arrived. in-band DTMF tone detection is turned off.
    11:38:57.468 CallLegImpl::eek:nConnected [CM103001] Call(9): Created audio channel for Ln:10000@Zingo (207.218.174.156:50620) with Media Server (67.53.129.195:9016)
