Dropped Calls
Discussion in '3CX Phone System - General' started by mobilesoundz, Aug 10, 2011.
  1. mobilesoundz
    Oct 24, 2008
    19
    I am pretty new to this so after a little advise, it appears recently we have been getting dropped calls. We used to get these on the old version after 20 seconds but now it appears the call rings on the handset and before i can answer, it drops i ave looked at the server log but do not know what to try can any one give me suggestions, the log is below:
    16:06:22.390 [CM503003]: Call(2): Call to sip:15@192.168.0.1 has failed; Cause: 487 Request Cancelled; from IP:192.168.0.20:5060
    16:06:22.343 [CM503003]: Call(2): Call to sip:14@192.168.0.1 has failed; Cause: 487 Request Cancelled; from IP:192.168.0.20:5060
    16:06:21.937 [CM503008]: Call(2): Call is terminated
    16:06:19.640 [CM505001]: Ext.14: Device info: Device Identified: [Man: Siemens;Mod: C475;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [C475 IP/022270000000] PBX contact: [sip:14@192.168.0.1:5060]
    16:06:19.640 [CM503002]: Call(2): Alerting sip:14@192.168.0.20:5060
    16:06:19.312 [CM503025]: Call(2): Calling RingAll80:14Ext.1410Ext.1011Ext.1115Ext.15@[Dev:sip:15@192.168.0.20:5060]
    16:06:19.296 [CM503025]: Call(2): Calling RingAll80:14Ext.1410Ext.1011Ext.1115Ext.15@[Dev:sip:14@192.168.0.20:5060]
    16:06:19.265 [CM503004]: Call(2): Route 1: RingAll80:14Ext.1410Ext.1011Ext.1115Ext.15@[Dev:sip:14@192.168.0.20:5060,Dev:sip:15@192.168.0.20:5060]
    16:06:19.265 [CM503010]: Making route(s) to <sip:80@192.168.0.1:5060>
    16:06:19.265 [CM505003]: Provider:[grrr] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [MSSGW] PBX contact: [sip:443334443455@86.132.215.104:5060]
    16:06:19.250 [CM503001]: Call(2): Incoming call from 0800371104@(Ln.10002@grrr) to <sip:80@192.168.0.1:5060>
    16:06:19.093 [CM503012]: Inbound office hours rule (unnamed) for 10002 forwards to DN:80
    16:00:09.875 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    15:40:09.765 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    15:20:09.625 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    15:00:09.484 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    14:40:09.421 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    14:20:09.296 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    14:00:09.062 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    13:40:09.015 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    13:20:08.875 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    13:00:08.671 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    12:40:08.546 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    12:20:08.406 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    12:00:08.234 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    11:40:08.171 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    11:20:08.062 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    11:00:07.828 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    10:40:07.734 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.1:5060
    Many thanks Mobilesoundz
    10,375
    231
    It looks like the set, at IP 192.168.0.20, is causing the call to drop. Have you tried substituting another phone for that extension, to see if it is a hardware or configuration issue with that particular phone?
    The ringgroup contains other extensions that don't appear to be registered (the call is not being sent to them in this log). What happens if the other extensions ring at the same time? Do they continue to ring? What if Ext 14 is not registered?
