Dropped Calls
Discussion in '3CX Phone System - General' started by badsushi, May 13, 2013.
  1. badsushi
    Mar 26, 2011
    27
    Anybody out there have an issue with dropped calls on outbound calls only - We have found via wireshark we are getting a t.38 invite on an established 7.11 call and the system responds with a 488 not acceptable code and drops the call
    the issue is very intermittent and will always drop within the 1st 10 seconds of the outbound call
    The system is ver 11 sp4
    We thought we were doing right by using supported Sangoma A101 cards but conveniently 3CX has dropped Sangoma and both manufactures are blaming each other.
    I'm curious if we shell out another couple thousand bucks on Patton product if it will even solve the issue.
    Any advice would be helpful~!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    253
    We have been on 3cx for 1 year using a Patton with an IA line. I have not heard of 1 complaint yet. And when I needed help Patton support was always right there with a quick and correct answer.
    You may want to consult with them before buying - they might have some insight for you in hopes of gaining your business.
  3. mlump
    mlump New Member
    Feb 24, 2012
    113
    Are you getting the T.38 invite from the PRI provider or is 3CX sending the invite. If you could post the relevant info from the capture that would be helpful.
  4. badsushi
    Mar 26, 2011
    27
    I think that's the issue with the onboard cards is you can't really tell who is providing the invite which is probably why 3CX went with external gateways
    Just a tough deal with you go with a supported product - somewhere along the line they drop it and your SOL
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    It looks like you are dialing out from a Cisco phone back into 3cx with a did (4947840). Where does this did go, your fax server possibly? 3cx is ending the t38 invite and the Cisco phone is rejecting.
  6. badsushi
    Mar 26, 2011
    27
    That is a land line - via wireshark you can hear them having a conversation for a few seconds before they get dropped.
    Update: we have disabled t.38 completely from net border express - going 12 hours so far - keeping my fingers crossed
