DTMF as BLF Type
Discussion in 'Ideas' started by atlantis2, Sep 8, 2017.
DTMF as BLF Type 5 5 6votes
5/5, 6 votes
  1. atlantis2
    May 3, 2016
    It would be great to add the Type DTMF as BLF Key.
    Yealink supports this type.
    It's used for example to send a pre-defined set of numbers.
    This can be useful for opening some door systems by phone.
    site likes this.
  2. decalabs
    Sep 21, 2016
    15
    For Snom-phones, just configure a key as "custom speed dial" and add for example "12345;dtmf=6789#" (without the quotes). On press the phone will dial 12345 and sends 6789# as DTMF. If you need a 1 sec. pause, add a comma (",") somewhere.
    See: http://forum.snom.com/index.php?showtopic=6291
    I haven't tested if this works with ";dtmf=6789#" for sending DTMF tones only without dialing a number. Maybe this works for you.
    extremit and AH2 like this.
  3. ghalan
    Nov 27, 2013
    13
    Hello, I would like just send DTMF without dial.
    I try ;dtmf=6789# or dtmf=6789# and doenst work
    Rgds,
    Yves
    extremit and site like this.
  4. atlantis2
    May 3, 2016
    Any updates on this? Would be great to have DTMF as BLF.
  5. timmbo
    Aug 25, 2017
    89
    34
  6. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,048
    156
    Done this on Yealink T42, using a custom template.
    Lines to add
    linekey.x.label = Gate
    linekey.x.line = 0
    linekey.x.type = 11
    linekey.x.value = 36174
    Change the variables to fit your setup.
    linekey.x to which linekey required
    linekey.x value is the DMTF code.
  7. timmbo
    Aug 25, 2017
    89
    34
    yes it may work, but this isn´t a professional kind to fix the problem.
    And for me 3CX is prof Equipment.
    We here in Austria uses a lot of Door-Opener with DTMF.
    Bye
    Timm
  8. JakeC
    Jun 11, 2018
    16
    Any solution for this?
    Yealink supports it out-of-the-box, however every time the phone is provisioned, the shortcut (to open the door) is automatically erased.
    When will 3CX support DTMF in their "BLF" section?
  9. YonNomNom
    Jun 10, 2018
    17
    +1 this would be great
