DTMF control on the server side
Discussion in '3CX Phone System - General' started by chikara sugiyama, Jul 15, 2014.
  1. chikara sugiyama
    Jun 15, 2014
    22
    Hello
    Although you have previously set up a separate set of DTMF or client terminal
    Setting the DTMF possible? On the server side?
    It is the best if you can provisioning
  2. MariosS_3CX
    May 26, 2014
    12
    Hey there,
    Could you please describe your issue in more detail. What do you mean by "Setting the DTMF"?
  3. chikara sugiyama
    Jun 15, 2014
    22
    Thank you.
    It is in the setting of Android or 3CX for windows, it is a DTFM Method.
