Solved DTMF issues with Snom
Discussion in '3CX Phone System - General' started by denko2k, Mar 22, 2018.
  1. denko2k
    Mar 20, 2018
    30
    Hello!
    We have problems with DTMF tones on Snom D715, D765 and D725 phones. At irregular intervals, the Snom phones stop sending DTMF tones.
    Firmware on the devices is the 3CX version 8.9.3.66
    After a restart, the problem is gone for a short time. But comes back at irregular intervals.
    Are there any solutions?
    We also unse the Snom DECT M700 system. DTMF here works perfect.
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,412
    186
  3. denko2k
    Mar 20, 2018
    30
    Thank you.
    The codec for the SIP trunk is G.711 A-law. The SIP provider supports this codec only.
    It is the same issue with internal and external calls.
  4. StefanW
    Jun 2, 2009
    1,222
    93
    the firmware 3CX ships is "8.9.3.87" and addresses an issue which took some time until the source was found in relation to the loss of DTMF functionality.
    Plz update and let us know.
  5. denko2k
    Mar 20, 2018
    30
    hello. 8.9.3.87 is out since yesterday? It seems to work now after the update. This would be great! We had issues the last 6 months.
  6. denko2k
    Mar 20, 2018
    30
    Hello again. Snoms with 8.9.3.87: DTMF now works fine. Thanks for your help!
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Glad to see the issue has been resolved
    denko2k likes this.
