DTMF key in 3CX Client and Phone
Discussion in 'Ideas' started by StefanK, Aug 29, 2017.
DTMF key in 3CX Client and Phone 5 5 7votes
5/5, 7 votes
  1. StefanK
    Sep 1, 2016
    A DTMF key for the BLF key field should be available in the 3CX Client to send a DTMF sequences. (For door openers for example). Yealink and snom phones does have this keys allready.
  2. extremit
    Aug 21, 2015
    I think, this is a "must have" function for a telephony system !!!
    JakeC and atlantis2 like this.
  3. atlantis2
    May 3, 2016
    please add this
    JakeC and extremit like this.
  4. xantip
    Apr 24, 2012
    14
    I think it's a little complexer than this.
    You have to answer the call and send a DTMF code to the key.
    In most VOIP doorphones, you can choose any DTMF code you want to open the door.
    I you take for example the * code, you answer the call from the doorphone and push *. What's the difference with answering the doorphone call and push a BLF to open the door? You don't gain any time and loose a BLF.
    I would go one step further. I want the possibility to put a macro behind a BLF.
    But it's only usefull in this scenario (for a doorphone at least, there coulde be much more interesting applications for this):
    - the doorphone rings and you have a visual view on the door
    - by pushing a BLF with a macro, the call is answered, DTMF code for opening the door is sent and the call is ended
    If you can't see the door and see who is standing in front of it, you have to answer the call anyway...
    Best,
    Jos
    #4 xantip, Sep 8, 2017
    Joe W likes this.
  5. JakeC
    Jun 11, 2018
    23
