DTMF not recognized external calls
Discussion in '3CX Phone System - General' started by wilco, Dec 11, 2007.
  1. wilco
    Nov 12, 2007
    36
    If i call from the outside to the server i cannot use the IVR menu. It seems like that the DTMF tones are not recognized by the Mediaserver. When dialing to an extension which is connected to the 3cx server and press some digits on the phone you can hear them over the speakers. So, the DTMF are send in the voice stream.
    When dial internal it works fine but the digits will be send not in the voice stream.
    Is there something else we could check?
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    did you make an Digital Assistant Wave and configuration?
    That should work
  3. wilco
    Nov 12, 2007
    36
    yep
    with the softphones is it working great.
  4. wilco
    Nov 12, 2007
    36
    i see the log that its reconized my dtmf tone
    18:00:07.511|.\MSEndPoint.cpp(1437)|Trace5||??:EP:00000001@ refreshed
    18:00:08.761|.\MediaServer.cpp(801)|Trace5||??:EP 00000003@.Start to play prompt
    18:00:21.591|.\DtmfRecognizer.cpp(253)|Trace5||??:Dtmf sound detected key #2('2') pressed timestamp=113180
    18:00:21.591|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #2('2') begin on 00000001@
    18:00:22.771|.\DtmfRecognizer.cpp(253)|Trace5||??:Dtmf sound detected key #2('2') pressed timestamp=122472
    18:00:22.771|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #2('2') begin on 00000001@
    18:00:23.790|.\DtmfRecognizer.cpp(253)|Trace5||??:Dtmf sound detected key #2('2') pressed timestamp=130752
    18:00:23.790|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #2('2') begin on 00000001@
    but what can i change?
    i want to buy this product but if the Digital Receptionist is not working!
  5. wilco
    Nov 12, 2007
    36
    PS:
    i cannot edit my posts?
  6. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    yeah there is some issue with edit function, please enter a new post with the edited contect..
  7. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    please let us know the scenario of the incoming call whether its coming from gateway or voip provider to DR of 3CX system.
  8. wilco
    Nov 12, 2007
    36
    It is comming from my voip provider to the adsl modem and than to my computer(vista)
    Local from my ip phone to the Digital Receptionist its working greet
  9. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Mind that some codecs like GSM and G.729 is not lossless codecs, so inband DTMF signal may become unrecognizable. Most systems don't even try to recognize DTMF on GSM stream, we're doing it quite successfully.
  10. wilco
    Nov 12, 2007
    36
    i can use
    g711a
    g729
    g723.1
    i.lbc
    I dont no witch i can or must use.
  11. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    3CXMediaServer.trace.log is a key, if you suspect it.
    It will be very helpful if you specify your VoIP provider as well as model of your phone
  12. wilco
    Nov 12, 2007
    36
    my voip provider is solcon.
    i use X-lite en 3cx voip client on my computer
    and a linksys ip phone spa921
  13. wilco
    Nov 12, 2007
    36
    can it be a vista problem(communication)?
  14. SY
    3CX Support
    Jan 26, 2007
    1,825
    wilco,
    The recognition depends on audio quality.
    Please provide 3CXMediaServer.trace.log for problematic call. If you can provide capture of network traffic on PBX host for this call (using WireShark) it will be event better.
  15. wilco
    Nov 12, 2007
    36
    I send you my log file!
  16. wilco
    Nov 12, 2007
    36
    My log file of the mediaserver contains the following. As you camn see i push serveral digits 2219#
    a=rtpmap:8 PCMA/8000
    a=rtpmap:101 telephone-event/8000
    a=sendrecv
    20:07:16.910|.\MSEndPoint.cpp(1437)|Trace5||??:EP:00000001@ refreshed
    20:07:18.974|.\MSEndPoint.cpp(1430)|Trace5||??:resynchronization. timediff:472
    20:07:18.974|.\MSEndPoint.cpp(1437)|Trace5||??:EP:00000001@ refreshed
    20:07:22.939|.\MediaServer.cpp(801)|Trace5||??:EP 00000005@.Start to play prompt
    20:07:34.209|.\DtmfRecognizer.cpp(253)|Trace5||??:Dtmf sound detected key #2('2') pressed timestamp=182300
    20:07:34.227|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #2('2') begin on 00000001@
    20:07:35.851|.\DtmfRecognizer.cpp(253)|Trace5||??:Dtmf sound detected key #2('2') pressed timestamp=195272
    20:07:35.851|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #2('2') begin on 00000001@
    20:07:37.349|.\DtmfRecognizer.cpp(253)|Trace5||??:Dtmf sound detected key #1('1') pressed timestamp=207416
    20:07:37.349|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #1('1') begin on 00000001@
    20:07:38.550|.\DtmfRecognizer.cpp(253)|Trace5||??:Dtmf sound detected key #9('9') pressed timestamp=216892
    20:07:38.550|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #9('9') begin on 00000001@
    20:07:39.328|.\DtmfRecognizer.cpp(253)|Trace5||??:Dtmf sound detected key #11('#') pressed timestamp=223240
    20:07:39.328|.\DtmfRecognizer.cpp(266)|Trace5||??:New tone #11('#') begin on 00000001@
    20:07:43.830|.\MediaServer.cpp(972)|Trace5||??:EndPoint 00000001@ removed from call 1
    20:07:44.069|.\MediaServer.cpp(979)|Trace5||??:EndPoint 00000005@ removed from call 1
    20:07:44.070|.\MediaServer.cpp(731)|Trace5||??:references to EndPoint 00000005@ were removed
    20:07:44.075|.\MediaServer.cpp(731)|Trace5||??:references to EndPoint 00000001@ were removed
    20:07:44.075|.\MSEndPoint.cpp(528)|Trace5||??:EndPoint 00000001@ destroyed
    20:07:44.075|.\RTPReceiver.cpp(127)|Trace5||??:Endpoint for socket 768 is not found!
    20:07:44.136|.\MediaServer.cpp(1050)|Trace5||??:references to call 1 were removed
    20:07:44.137|.\MSCallConf.cpp(31)|Trace5||??:Call: 1 destroyed
    20:08:29.909|.\FileCache.cpp(235)|Trace5||??:Cache (*.mp3) in directory ..\data\ivr\prompts
  17. wilco
    Nov 12, 2007
    36
